Cantungman
Hello Kity Problem solved so on to the next problem. Does anyone know where I can get a MacAllister COD2000FLS manual? It seems to be surprisingly hard to find. I have changed the drive belt but cannot figure out how to tighten the belt. In the loose position the belt is stuck against belt cover housing at the static end. It appears that as you tighten the belt the static end will be pulled away from the housing (not that static then?). Any advice would be appreciated. Cheers!
