Found this on the net but I thought it was a good idea so I made one and thought you may like to see how I did it
The parts you'll need
You will have to drill and counter sink the holes
Screw square to the end of a block
The only slightly awkward bit needs to be shaped to fit
Screw this to the other arm
In use all you do is hold down the gauge using the block and raise the blade, works just as well with router tables
Hope someone finds this usefull...
Lee
Lee
